Mahogany question
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=8460
Author:  nathan c [ Fri Sep 15, 2006 12:42 am ]
I was in a local (30 miles) lumber distributor when I ran across some Ugandan Mahogany. I've done some research on the web and found it's also called "munyama". It's a rough cut piece about 2" x 9" x 30". It was about $15, which is about $30 cheaper than regular African mahogany of the same size, so I picked it up.   It's more blonde than regular mahogany too. I was curious is this a species (spelling?) that could be used for back & sides? If so I'll try my hand at resawing . If not I'll use it in a different project. Thanks.
Author:  Don Williams [ Fri Sep 15, 2006 12:54 am ]
Hi Nathan,
Almost any hardwood can be used for back and sides. They will all sound differently, but many will work. This may not be a true mahogany, but then there's 100's of woods around the world being called mahogany that aren't.
Author:  Bobc [ Fri Sep 15, 2006 1:26 am ]
Nathan it's african mahogany. It should work fine.
Kahya anthotheca is also known as krala (Ivory Coast): mangona (Cameroons): munyama (Uganda).
